stephenbright
Export the FFF Process from a S3D gcode file....
Tue Jun 23, 2020 6:45 pm
Is there a way to export the FFF process from a S3D gcode file without manually sifting through an exported gcode text file? In short I have a S3D print ready gcode file that prints perfectly, however when I open it in S3D I can't seem to edit the FFF process any further. I inadvertently deleted the FFF process and I basically want to extract the working FFF process from the gcode file and use that process with other models. Is this possible without manually entering the data from the text file?
S3D-Alex
Re: Export the FFF Process from a S3D gcode file....
Wed Jun 24, 2020 8:01 am
You can import a Simplify3D gcode file as an FFF profile. Just go to File > Import FFF Profile and select the gcode file you are referring to. This will import a profile of the settings used for that file.
