fredlef
Lower the nozzle prior to printing.
Mon Jul 27, 2020 6:05 pm
I have been having some challenges getting front to back levelling with my Flashforge Creator 3. I have it sorted if I can just have the nozzle start about 1.28mm lower than 0. (-1.28). I thought i could do this using the gcode tab offset but that moves the model. Is there a way I can tell it to start the print with the nozzle at -1.28 - or thereabouts?
Thanks,
Fred
parallyze
Re: Lower the nozzle prior to printing.
Mon Jul 27, 2020 7:45 pm
What offsets did you use on the G-Code tab? The "Global G-Code Offsets" or Origin offsets inside the machine defintion?
I've been using the Global offsets/Z very often without any trouble... not to an extent of > .1mm but it did what to expect from it...
fredlef
Tue Jul 28, 2020 8:18 am
Thanks for the response. I'm not sure where I got off track but I did go back to the most basic configuration and put in the global offset and it is now working ok. Thanks
