unable to switch off retraction
Posted: Sun Sep 06, 2020 6:26 am
by touchthebitum
Hello
I'm struggling against turning off retraction. I checked off all menus but still active.
Any ideas ?
Re: unable to switch off retraction
Posted: Tue Sep 08, 2020 11:02 am
by S3D-Alex
In the Extruder tab of the Process settings if you uncheck the box labeled "Retraction" under the Ooze Control section this will ensure no retractions are placed in the gcode.
Posted: Tue Sep 08, 2020 12:24 pm
by touchthebitum
already done but it doesn't work ...
Posted: Tue Sep 08, 2020 12:38 pm
by S3D-Alex
Could you please send a gcode file where you are seeing retractions even when the retraction box is unchecked?
Posted: Tue Sep 08, 2020 12:42 pm
by touchthebitum
Here it is
Posted: Tue Sep 08, 2020 1:13 pm
by S3D-Alex
It looks like you have the option labeled "Include M101/M102/M103 commands" enabled. These are older commands that cause primes and retractions so it looks like these are causing retractions to still occur on your printer. Please go to the Gcode tab of the Process Settings and uncheck this box to make sure no retractions occur.
Posted: Tue Sep 08, 2020 1:20 pm
by touchthebitum
Ok, I'll try it
Thanks
