Omikron
Only infill being sliced?
Wed Oct 14, 2020 5:32 pm
I admit I've gotten rusty on S3D since I switched away but I thought I'd give things another shot.
Today I ran into an unusual problem. When attempting to slice an object only the support material was sliced. Here is the object on the plate:
However when I slice it, this is what I get:
What stupid thing am I missing?
Omikron
Re: Only infill being sliced?
Wed Oct 14, 2020 5:57 pm
Even though my copy of S3D was activated and licensed it looks like until I unblocked it from the firewall it was causing this problem.
The only reason I discovered it is because I attempted to run the machine setup wizard again and discovered it was blocked.
This is poor license management on S3D's part. If there is a suspected issue regarding the licensing status of the software it should be made clear to the user. Sabotaging slicing operations in this way is not a reasonable way of handling things.
