No retraction
Posted: Sat Oct 24, 2020 5:57 am
by littleblackdog11
I'm finding that retraction is not done when in the support building phase, when it moves between different areas of support. As a result, the slight ooze is getting onto the part. Retraction works fine in the part building phase of the layer.
Is there a way to fix this? I don't see a setting in support for that.
Re: No retraction
Posted: Tue Oct 27, 2020 1:57 pm
by S3D-Mitch
Could you share a Factory File that shows this behavior? The Factory File contains complete information about your project (model, printer, process settings, etc.). To create the file, open the software and load your project. Then go to File > Save Factory File as...
