Hello, I'm having trouble getting my buildplate to heat. I have a working gcode file that does heat, but all my new files made with Simplify3D do not heat the plate.
My scripts:
T0; always home on the right extruder
M73 P0 ; Enable build progress
G162 X Y F3000 ; Home XY maximum
G161 Z F1200 ; Home Z minimum
G92 X0 Y0 Z-5 A0 B0 ; Set Z to -5
G1 Z0 ; Move Z to 0
G161 Z F100 ; Home Z slowly
M132 X Y Z ; Recall home offsets
G1 X-95 Y-70 Z30 F8000 ; Move to wait position off table
M126 S[fan_speed_pwm] ; Set fan speed
M140 S[bed0_temperature] T0 ; Heat buildplate
M104 S[extruder0_temperature] T0 ; Heat right extruder
M116 ; Wait for all temps to be reached
G130 X118 Y118 Z40 A118 B118 ; Default stepper Vrefs
G92 A0 B0 ; Zero extruders
G1 X100 Y-70 F9000 ; Move to front right corner of bed
G1 Z0.3 F6000 ; Move down to purge
G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed
G1 X-100 Y-70 F180 ; Wait for ooze
G1 X-110 Y-70 F5000 ; Fast wipe
G1 Z0.5 F100 ; Lift
G92 A0 B0
M73 P1 ; @body (notify GPX body has started)
I've tried to copy the same scripts from the working Gcode over but that didn't seem to work.
