Hi there,
I'm having trouble figuring out how the dual extrusion part of S3D works. I have figured out how to make the dual extrusion group, but it just doesn't work the way I need it to.
My problem is:
I have several profiles for different types of filament, so I have to switch between them from time to time, they're all set to "Both Extruders" in the "Auto-Configure Extruders". However, when I check the "Left Extruder" it says the primary extruder is the "Left Extruder", and when I check the "Right Extruder" it says the primary extruder is the "Left Extruder" too. So I change that to "Right Extruder" and it works just fine, but if I switch to another profile and go back to the first one, it has changed the "Right Extruder" primary back to "Left Extruder".
Am I overlooking something very simple or am I just plain dumb?
