Bibbinator
Raise3D Pro2 Profile oddity?
Wed Apr 21, 2021 5:51 am
I chose Raise3D Pro2 as my printer and when I went to slice I see the build volume is truncated on X. I went to preferences and I can see there is an offset there and the X build volume dimension is smaller and it should be the same as the Y axis (305 mm). Is there a reason the full build volume isn't being used? Is this a bug?
Thanks,
Brett
