PhillipM
Crashing issues, with Windows 10, 21H1
Recently did the latest 21H1 update, along with updating my AMD drivers to 20.6.2 - I'm having crashing issues with simplify just closing with no error messages, I tried rolling back to the 20.6.1 AMD driver, no change, so I'm wondering if it's the latest windows updates, anyone else having problems?
Re: Crashing issues, with Windows 10, 21H1
Have you tried exporting your profiles with File > Export FFF Profile and then using Help > Reset All Settings? This will revert Simplify3D to its stock configuration.
After this is done you can import your saved profiles with File > Import FFF Profile(s).
Not sure if this is connected with the reported issue here....but there have been reports of issues printing to Sillhouette Cameo 2D cutting devices since a recent update to Windows. Microsoft have acknowledged the issue and may be working on a quick fix to the fix!
I've had problems wring to my Cameo....and removing the updates KB5003537 and KB5004945, tthings started working again. I have no issue with S3D...but that may not be an indication the windows fixes are not responsible.
Update: The fix with the issue is KB5004945, and it was patched on the 6th July 2021
