reddadsteve
Object scaling issue after auto scale does it's job
Mon Dec 15, 2014 2:42 pm
I believe I had the following issue prior to 2.2 but was just able to pin it down today. I figured that I was just working too fast and making mistakes.
When importing a 'small' object, the auto scale option kicks in and converts the object to inches with a scale of 25.4. This in itself is not a problem since the object is now quite large and obviously needs to be scaled accordingly.
The issue is that after double clicking the object and entering a value for the scale required, the dialog box itself seems to handle the new scaling properly. However after hitting save and closing the dialog box, I find that the object scale is reset to 5.08! Odd number but always the same 5.08.
Going back to re-scale a second time, the dialog box works properly and I'm able to get the scale required without having to reload the object.
Thank you,
Steve
bryan
Re: Object scaling issue after auto scale does it's job
Tue Dec 16, 2014 12:12 am
The square root of 25.4 is 5.04. Not sure what 5.08 is.
--Bryan
reddadsteve
Thu Dec 18, 2014 10:39 am
Can someone confirm that they can reproduce the same issue? I'm running windows 8.1
I've disabled the auto scale option and simply cancel the prompt when the software asks if I want to convert from inches to mm. i then perform whatever scaling I need at that point with no issue.
Thanks,
Steve
bryan
Thu Dec 18, 2014 11:25 am
2.54 * 2 = 5.08
