nevarore
Top and bottom layers speed
Mon Jan 05, 2015 5:06 pm
I try to decrease the top speed layer.
I use 'solid infill underspeed' in the 'other' tab.
It is working well for the bottom layer ( first layer ) but the printer doesn't decrease the speed for top layers and all upper part of the print.
I miss something ?
KeyboardWarrior
Re: Top and bottom layers speed
Tue Jan 06, 2015 2:53 pm
The Solid Infill Underspeed changes the speed for all solid layers. Under the layer tab you can set the # of top and bottom solid layers to have. It's possible your Top solid layers is set to 0, but I think stock profiles they're usually set to 3 each. Also, if you have infill at 100% the Solid Infill Underspeed will slow those layers down too.
nevarore
Wed Jan 07, 2015 3:56 am
Thanks a lot.
