greedseed
Top and bottom solid layer setting broken
Sun Jan 11, 2015 9:15 am
Okey, simple problem.
Sertting the Top and Bottom solid layer option is broken!
Setting the bottom to 3 and the top to 10 makes it prints 10 on the bottom and 10 on the top.
Setting it to bottom 3 and top 1 just messes it all up. This needs to be resolved! If i want only 2 layers on the bottom to prevent warping, and i want 10 on the top to make sure it seals all the way, i need to be able to do so!
Re: Top and bottom solid layer setting broken
Mon Jan 12, 2015 5:27 am
It woks absolutely fine for me. Setting top solid layers to 10 and bottom solid layers to 3 functions exactly like you would expect. Post a factory file if you are still sure something is wrong
Mon Jan 12, 2015 7:32 am
Agree with joe. I have never had that issue here. You gotta post it up ir no one can help
