Rebekah_harper
Massive shift in x-axis
Sun Feb 08, 2015 6:53 am
Hiya,
I run a wanhao 4s. I've printed high object fine. To print a large area object on oh my lord this occurred.
It shifted massively.
Any ideas?
Re: Massive shift in x-axis
Sun Feb 08, 2015 2:51 pm
Could be a mechanical issue. Many times print shifts like that are due to skipping motors, loose screws, or bad tension on the belts
Sun Feb 08, 2015 6:00 pm
also can be cause by your print curling and warping, over extrusion or anything else that will cause the nozzle to catch on the print as its whizzing around. it doesnt take much to knock the nozzle and cause some skipped steps.
Rebekah_harper
Mon Feb 09, 2015 8:27 pm
Cheers guys.
I will investigate you suggestions.
