I'm having the same issues with printing at .1 layer height (Replicator 2X). The extrusion is blobby and there seems to be a bad calculation on the gap required between each shell. I haven't played with a manual setting yet for the extrusion width but that might help.lotw wrote:I have at issue too, if printing at low layer heights where other slicers work fine. There seems to be a gap between each line instead of making it run up next to it. Like it is calculating the next move slightly off leaving a gap between bigger then the plastic can fill.
