Mind the gap.
Posted: Fri Feb 13, 2015 2:05 pm
by Rebekah_harper
Hiya all,
I've managed to get rid of the over blobbing. How ever I'm not getting gaps. Quite uniformed. I got an idea what it could be but want your opinions as to what it could be.
Any help would be appreciated.
The settings for the extruder are 0.91 and width on manual set to 39.
This isn't the firs time I've had this but with default settings.
Re: Mind the gap.
Posted: Fri Feb 13, 2015 9:43 pm
by dsegel
I don;t understand what the problem is. Can you post the stl file itself so I can see what the goal is?
Re: Mind the gap.
Posted: Sat Feb 14, 2015 8:27 am
by jimc
you have the extrusion width set at .39. what is your nozzle size?
Re: Mind the gap.
Posted: Sun Feb 15, 2015 1:17 pm
by Rebekah_harper
Hiya,
It's a 0.4 mm nozzle.
I have managed to resolve it. So many tweaks but got there. Used filament size 1.73, multiplier at 0.96 and the extrusion width at 0.39
In combination they seem to work for my printer nicely.
I couldn't say if it's all contributing to the solution but I get the results I'm looking for
Re: Mind the gap.
Posted: Sun Feb 15, 2015 10:20 pm
by jimc
ok just an fyi, your nozzle wont print at .39 width. it should print at .48 or higher. you can go slightly lower but the closer you get to .4 or even under you are going to run into problems especially in areas that are not printed 100% solid. you end up with stringy prints with broken under extruded infill.
Re: Mind the gap.
Posted: Thu Feb 19, 2015 6:56 am
by Rebekah_harper
Believe it or not it does print. I can't explain why or how. Don't forget I'm using a Wanhao 4s and if there is anything I have learnt from the Chinese products, they don't conform to convention.
