scooter217
Filament coming out slow and clogging
Sun Feb 15, 2015 8:22 pm
At first i thought it may be the bed needing to be adjusted but i am able to print things fine in MakerBot. When i try to print in Simplify3d, the abs filament comes out slow and clogs up. I am using a CTC 3D dual extruder printer.
Re: Filament coming out slow and clogging
Mon Feb 16, 2015 7:07 am
Are you only seeing this for the first layer, or does it occur for the entire part (even 10 layers up)? Have you set your filament diameter correctly?
