Double extrusion problem
Posted: Wed Feb 18, 2015 7:22 pm
by thekkiinngg
Hello i have a flashforge Creator and i try to print whit dual extrusion first layer whit flex fillament left extruder and infil whit ABS at right second extruder the first layer all is ok but when to arrive at the right second extrudor the printer stop and Spit a heap of plastic ( BLOP'BLUP) before of advance see my picture i try deferent solution but i do not works :( please help me to remove right extruder blop before start to infill thanks.
Re: Double extrusion problem
Posted: Thu Feb 19, 2015 7:22 am
by JoeJ
Maybe you need to clean and purge the nozzle before starting the print. You could always edit your starting script to do that automatically too
Posted: Thu Feb 19, 2015 8:11 pm
by thekkiinngg
Do you have a scrip to purge the extruder before restart ? i think the extruder is purge corectly but is purge over the parts before restart is it possible to purge at the same place at the start first layer ???? outside the heated bed Platform ? thanks for reply .
Posted: Fri Feb 20, 2015 6:22 am
by JoeJ
Just look at your starting script. All the commands are commented pretty well. I think it already purges the right extruder. So just copy/paste that section and add a T1 before it so that it now purges the left nozzle.
