Ola
Dual print - can not rotate 2 objects
Sun Feb 22, 2015 8:20 pm
Trying to print an assembly with two objects = dual printing with different materials.
Assembly is created with two parts in correct relative position.
When placing the different objects on the plate, I need to move and rotate them (around x- or y-axis) to another position but the software only allows for moving and rotating in the x-y-plane, not rotating around x- or y-axis.
I can only rotate one object at a time. This messes up things because then the relative position of the two objects are lost and they cannot be printed.
How do I rotate two objects at the same time (for example 90 degrees around x-axis) keeping their relative orientation?
Re: Dual print - can not rotate 2 objects
Mon Feb 23, 2015 5:44 am
You might want to read this: https://www.simplify3d.com/support/tuto ... extruders/
To summarize, if you just hold the shift key while using the mouse/keyboard shortcuts to move or rotate the models, it will actually move/rotate ALL of the models on your bed. So it makes it easy to quickly position multiple parts that have already been correctly placed relative to one another.
Ola
Mon Feb 23, 2015 5:09 pm
Sorry, I didn’t express myself clearly.
I am talking about rotating around the x- or y-axis. (I edited my previous post)
Rotating around the z-axis is easy, as you describe. But any other rotation can only be done one object at a time. This is very irritating. :(
This is very easy to do in Makerboot.
Is there any easy workaround?
Are there any mouse/keyboard shortcuts to rotate around x- or y-axis?
