schlitt1968
WARNING: CRC mismatch detected
Sun Mar 08, 2015 11:09 pm
Testing alternate communication protocols...
RECEIVED: XZ@D
Attempting RTS reset and trying again...
Connection failed.
I am using the flash forge pro
and I cant connect via usb the simplify3d to the printer..Anyone seen this know whats up?
Re: WARNING: CRC mismatch detected
Mon Mar 09, 2015 7:35 am
Hmm... never seen that before. What firmware did you put on there? I'm shocked to see any plain-text responses from what should be a binary-speaking machine
BigDaddio
Sun Jul 19, 2015 9:40 am
OK yea this is weird I have been getting CRC mismatch with my FlashForge as well. It does however connect and work just fine. I may have been getting them all along I only noticed after I clicked off verbose communication. I am using sailfish couldn't say what version at the moment. I have not upgraded it in over a year. I really don't see a need to and it was a pita.
AndySimplify3D
Sun Jul 19, 2015 4:47 pm
FWIW, I too just got this error with a new Delta - however it seems to come when Simplify 3.0 cannot connect fast enough to the RAMPS 1.3 - I disconnect and connect again and it connects perfect each time.
Using RAMPS 1.3 with Arduino Mega 2560, marlin latest...
I have a feeling it may be a USB issue of crosstalk or dodgy soldering on the USB port, or elsewhere on the board (its a "cheap" one!)
total a minor bug - I haven't tried printing once connected with this error, I've preferred to reconnect each time...
Andy
JATMN
Mon Jul 20, 2015 11:01 am
I haven't had CRC mismatch errors.. but I have had alot more communication issues with my Wanhao D4 than i did with 2.2 usually only resolve is to close S3D and turn off the printer then launch S3D and turn the printer back on.. usually have to do this 2-3 times before im able to print. I will try to post the console text next time.. but mine talks about plain text as well when its doing that..
Jack of All Trades Master of None
Wanhao Duplicator 4 (MFG 2013) + Simplify3D v3
Ultimaker v2 + Simplify3D v3
Ultimaker v2 - Aluminum - Remix By JAT.MN + Simplify3D v3
meshbuilders
Mon Aug 10, 2015 3:50 pm
I just upgraded to Windows 10 and started having this issue connecting to my FlashForge Creator Pro.
This is the last few lines from the communication window:
SENT: d50115a2
WARNING: packet transmission failed, retrying... (d50115a2)
SENT: d50115a2
SENT: d50115a2
SENT: d502860085
READ: 81d2d501808cd501808cd50181d2d50181d2d501808cd501808cd501808cd501808cd501808c
WARNING: packet transmission failed, retrying... (d502860085)
SENT: d502860085
SENT: d502860085
SENT: d502860085
SENT: d502860085
SENT: d502860085
SENT: d502860085
SENT: d502860085
READ: d50181d2d501808cd50181d2d501808cd50181d201d580
SENT: d502860085
SENT: d502860085
READ: 8cd50181d2d50181d2d501808c
SENT: d502860085
READ: d50181d2
SENT: d5030a0002d6
READ: d50381d400aa
SENT: d5030a010212
READ: d50381320075
SENT: d5030a001ee8
READ: d503815a0059
Disconnected.
As far as I know it is the most recent version of sailfish. I'm currently attempting to print and will double check once it either fails or finishes =)
alex_h
Fri Sep 18, 2015 11:39 am
I also have been getting the packet transmission failed since updating to windows 10 on my Sailfish Replicator 2. Has anyone any ideas about this?
Sat Sep 19, 2015 4:43 am
There's many threads on this already. It's related to a bug in Windows 10 that affects some specific serial port drivers. Not much we can do except wait for a fix from microsoft (or downgrade back to Win7/8)
Rebekah_harper
Sat Sep 19, 2015 1:02 pm
hiya,
some may know some may not know. but the CRC is a Cyclic Redundancy Check as far as I know.
from what I understand is that the printer send a response to every command and it's this that causes the error.
I am running Sailfish 7.7 on a Wanhao D4S.
I get these errors every time. along with 'firmware version 0 detected' I have recently upgraded my HDD to SSD so I will give that a go to see if it's a speed thing on my set up. but I think it's a number of things.
Mainly the firmware on the printer as I was getting this on Win7 too. Without being able to see the full communications between the two I can't say exactly why but I'd like to think the Gods of S3D might come to some conclusion was to why it's occurring.
I have reported this a few times but I think it's got them stumped for the time being.
dvation
Mon Sep 21, 2015 5:21 pm
For whatever it's worth I've been getting these errors on Win 8.1 since flashing Sailfish myself on my Monoprice 3D Printer (Flashforge Clone - same print board) . I emailed support and they ran me through the usual generic stuff (usb cable, whatever)...didn't help. I can still print okay over USB though for whatever reason.
