MikaMa
Question about extrusion widht calibration
Tue Mar 31, 2015 6:44 am
I made profiles for 0.1mm, 0.2mm and 0.3mm layer resolutions and am manually calibrating them for optimal output. I managed to calibrate 0.3mm already with the following settings:
Nozzle diameter: 0.4
Extrusion multiplier: 0,92
Extrusion widht: 0,42
calibration went pretty close and the perimeter was smooth.
Now I am trying to calibrate 0.2mm but have some problems with the surfaces. I have now measured that with these calculations the result should be ok:
Extrusion multiplier: 0,85
Extrusion widht: 0,28
But the result is this:
One of the walls has tiny holes. The surface is otherwise perfect and smooth. I closely watched the printing and noticed when they were formed. Everytime I heard a "zap" sound and the hole appeared. SO my question is:
1) are the holes caused by moisture in the filament
2) Should I increase extrusion multiplier?
3) Should I increase extrusion width? (which is mathematically correct)
4) all of the above or something else?
any ideas :)
dennisjm
Re: Question about extrusion widht calibration
Tue Mar 31, 2015 9:13 am
Leave extrusion width at .42. When you put it to .28 only 1/2 the plastic is going to be extruded. It will also make the toolpath 1/2 the distance apart but really it's difficult to get good results not pushing enough plastic through the extruder.
For my profiles, I don't need to adjust extrusion multiplier and nozzle width when changing layer height. The software compensates for the amount of plastic you need for varying layer heights.
MikaMa
Tue Mar 31, 2015 11:28 am
I tried 0.42 but still gives me small holes.
MikaMa
Tue Mar 31, 2015 1:49 pm
The problem persist it seems.
I printed a cube with the following settings.
Top solid 0
Bottom solid 2
Shells 1
The print went otherwise good (wall thickness average 0.42, smooth 3 walls) but one wall still had few holes.
how to get rid of them?? Any tips
