dmsmith wrote:I would also be very interested if a solution has been found to this problem - I have just recently purchased both FFF and S3D after excellent feedback on various forums but the lack of preheating of the extruder is frustrating with the only work around to preheat through the FFF prior to sending the file over FlashPrint via. Wi-Fi.
I have since discovered the source of the problem however, I have no idea the reasoning behind it. I tried and tested removing different lines of G Code from the print file however, only one piece of the G Code caused the extruder to not heat up prior to printing... what makes it even stranger is that piece of G Code is a comment, and not part of the actual routine. You should try removing the following piece of information in italic bold below (note: only remove this from the comments section at the beginning of the file as it appears twice in the G Code routine - it is required at the end if the routine so don't delete that) and you'll see the extruder starts to heat up as expected prior to print: -
; endingGcode,
M104 S0 T0 ; cool down extruder,G1 Z140 F3300 ; send Z axis to bottom of machine,M107 ; disable cooling fan,G28 X0 Y0 ; home XY axes,M146 r0 g0 b0 ; Turn lights off,M18 ; disable stepper
If anyone can explain the reasoning behind this it would be much appreciated as it is a pain to go into every G Code file to delete that single piece of information prior to each print.
