bapro
Solid infill angel bug
Wed Oct 07, 2015 1:59 am
Solid infill angle don´t work at all. -45 or 45 degrees on solid infill no matter settings.
viewtopic.php?f=23&t=3617
Re: Solid infill angel bug
Wed Oct 07, 2015 7:46 am
I would probably call this a feature request. The infill angles that you specify are for the internal fill on the inside of the part. They don't have an option to change the external fill angles. Changing the internal fill angles works fine, but you are requesting that they add an option to adjust the external ones as well.
bapro
Thu Oct 08, 2015 2:55 am
That´s not true. That setting is for solid layers to. It´s a bug in V3.
Thu Oct 08, 2015 7:03 am
Go to the Infill tab and set your internal fill pattern to rectilinear. The internal fill angles will be +45/-45. Then change it to triangular. The internal fill angles now become 0/+60/-60. So if you were using rectilinear for the exterior fill pattern and triangular for the internal fill pattern, there's now way you could use the same angles. They need to be different.
The option they have in their now is only for the internal fill angle. If you change it, that's all that it adjusts.
bapro
Thu Oct 08, 2015 8:54 am
I can´t se any reason why it shouldn´t work with the new infill patterns and I haven´t found any documentation on this change. In V2 it works just fine and there is probably a lot of more reasons to change your solid infill angles than the internal if you want a good print. Now if Simplify launched the new infill patterns, despite knowing this effect, without doing something about it, they should be ashamed.
I choose to believe that it is a bug.
