Initial Wipe blocking nozzle
Posted: Fri Nov 13, 2015 12:46 am
Hi all,
I'm just getting started with S3D and am having difficulty finding information on the "wipe" action that occurs before each print begins. I am using a Flashforge creator pro.
At the beginning of each print, the nozzle begins extruding in the front right corner of the build platform and moves back and forth over half a centimetre about 3 times. It looks like it is trying to wip the nozzle or build up pressure before moving onto the rest of the job but every single time it does this filament globs around the extruder head and causes failed prints 100% of the time. Thus far I've been getting around it by pausing my prints after it does this wipe action, cleaning the nozzle then letting it proceed as normal.
What is this action called and is there an option to control it in S3D? On a side note, is there an easy way to get S3D to add a single extrusion line along the front of the build platform just before moving onto the brim?
Any help is greatly appreciated.
