I have a Makerfarm 12"x12"; and I've been able to get some really good resulting prints from it; but there is still an issue or 2.
When I set the extrusion multiplier to 1 and the extrusion override to 100%, I get under extrusion. I can fix this by setting the over ride to 125%, but the change doesn't happen immediately, and it affects the first layer or so. I've calibrated the extruder and that doesn't seem to be the issue.
I tried changing the value for the extrusion multiplier but can't seem to find the correct value to get the same results while leaving the over ride at 100%
So, I have 2 questions...
if I have a extrusion multiplier of 1.00 and an over ride of 125%, does anyone know what the inverse would be to get the same extrusion? or
Is there a gcode command I can put into the start script to set the over ride to 125% ?
any advice would be very helpful;
Lorcoft.
