MarkH
Issue with using S3D with a M3d and wrong gcodes
Fri Dec 04, 2015 1:29 pm
Hello all,
I was wondering if someone could point me in the right direction here. I am relatively new to using S3D so this may be something I have overlooked. I am importing .stl files. I click on the Process and go through the menus as much as I understand and check settings. I hit the prepare to print and then save a gcode file and load into m3d software via load print job. The m3d software goes through the processing and warming up and then fails with an unknown gcode. I think I added the m3d printer correctly to S3D. Not sure what I am missing here. Does anyone have experience with the m3d and getting this to work?
Regards
MarkH
Re: Issue with using S3D with a M3d and wrong gcodes
Sat Dec 05, 2015 5:56 am
Does it give you a line number or something in the error message so that you know what command is causing it?
Otherwise, perhaps you can compare a gcode file from S3D with one from the other software to look for differences in the commands (specifically, ones that are in S3D, but not M3D's)
MarkH
Sat Dec 05, 2015 9:47 pm
I will have to go back and look again.
MarkH
Sat Dec 05, 2015 11:03 pm
Well after some digging and comparing. I solved that part of my issues. I created a 1 inch cube stl file. I did a direct print in m3d( sort of I aborted the print) to get the file logged into it's que log. Basically a print log of the jobs and the gcode used for it. I then added the S3D gcode file via the advanced menu in m3d software. It bombed with the unknown gcode error. So I pulled that que logged file to see what it contained. I tried to do a direct comparison between the 2 que files to see if anything was obvious. Well the best I could tell is they have some differences. I am not a full fledge gcode coder so that makes it more of a challenge to a direct comparison. Needless to say I have been playing with it and looking around the web for info on what gcodes this uses. I have a small collection of 14 so far outside of the basics like absolute mode etc. While not extensive it does help me a small bit to see what they do, like heaters on etc.
When I was looking at the gcode from the S3D I kept seeing M101,102,103. Then it dawned on me that I saw that in the process menu, a check box for adding these codes. So out of curiosity I manual input them in the advanced menu in m3d, send command line to see what they did. Those are the codes that are unknown. So basically I had that check box on in S3d and the m3d does not recognize them as valid.
