Well you're not looking properly!!!I don't see any problems with the model.
Thanks! May I ask what you used to inspect / fix the model? (Was it netfabb?)
Cool. I have Win 10 in a VM, I'll give that a try Thanks.dkightley wrote: ↑Tue May 22, 2018 7:38 pm Here's a wonderful advantage of using Windows10...…..so the BG haters are disadvantaged!
In Win10 there's a utility called 3D Builder. On loading an stl file, it auto checks if there's any issues and prompts for permission to rectify them.....and it does! You then simply do a Save as" in the 3mf file format...and S3D will load and slice!
Thanks, but the ones you sent still have an extraneous bridging inside the "mouthpiece" component.
