I don't see a setting for vertical lift speed in the process settings. I'm concerned because looking at the gcode, I think it might be trying to move at whatever it's last speed was (which would be either the retract or XY, both of which are extremely fast)
The symptom I am seeing is my 80mm tall print coming out squished at 60mm printed. The final layer of gcode clearly calls for the nozzle to be at 80mm. I have confirmed that my steps-to-mm numbers are correct in my firmware.
It seems that I am losing zsteps somewhere, so I suspect the vertical lift speed is exceeding the capability of the machine. I am able to slice and print using cura/repetier without issue.
Anyone have any ideas?
