slow speed, when printing more than one object
Posted: Sat Mar 26, 2016 10:21 pm
by DirkT
Hello,
i use a ultimaker 2 Extended+ and have a problem with printing speed, when i print more then one object(stl-file).
When i print the files seperately, the printing speed is normal.
If i try to print more then on object, the printing speed is very slow. The travel speed is normal.
I attached an example file with more then one objects and hope you can tell me my mistake or notice a bug.
Thank you.
regards,
Dirk
Re: slow speed, when printing more than one object
Posted: Sun Mar 27, 2016 3:43 pm
It looks normal to me. Those are incredibly tiny thin pieces, so the software will try to slow down to make sure there's enough time for cooling.
You can disable the "adjust print speed for layers below XXXX seconds" option on the Cooling tab if you don't want it to slow down
Posted: Wed Mar 30, 2016 10:10 am
by DirkT
Hello,
CompoundCarl wrote:You can disable the "adjust print speed for layers below XXXX seconds" option on the Cooling tab if you don't want it to slow down
Thx for help. That's the tab, i haven't saw!
Regards,
Dirk
