Factory file is attached.
I printed this part with a .25mm nozzle wanting the vertical wall to print .3mm thick. It looks perfect on the preview (had to back the extrusion diameter down to .29 to remove the gaps), but when printing the nozzle makes two passes on each layer resulting in too much plastic per layer and a wall thickness of .5mm.
Why would the wall that's shown as one layer print two passes?
