bleeps
s3d not generating support
Tue Jun 07, 2016 11:42 am
I'm not sure why this feature isn't working. I've been able to generate supports on other files before. Suddenly it's not working on any model I try. The Factory File is attached. Am I overlooking something?
hilbert_cube2.factory
(45.56 KiB) Downloaded 62 times
andrewk72
Re: s3d not generating support
Tue Jun 07, 2016 1:42 pm
Your support pillar resolution is far too large for your model. Those beams are only a few millimeters thick, so you need to lower your pillar resolution to 1-2mm
Also, you might want to save some of those processes as actual filament or machine profiles. That makes things much easier to work with ;)
bleeps
Thu Jun 09, 2016 3:57 pm
That was it. Thanks!
And yes, I need to work on my workflow. I haven't done enough reading on what the different file/profiles save.
fbrier
Sun Mar 10, 2019 1:08 pm
Thank you. This was my problem as well. :)
