Extrusion (wall thickness) problem
Posted: Wed Jun 29, 2016 1:48 pm
just received my simplify3d an got some odd problems:
CTC 3d with sailfish
Nozzle: 0.4
Extrusion Width: 0.44
Extrusion Multiplier: 1.00
Extruder is calibrated right (100mm are 100mm), but when printing, a single line is about 0.8-0.85mm thick. And so the inner perimeters (holes) are about 0.4mm too small. Infill is good, little over extruded.
When changing Extrusion Multiplier to 0.5 i got a single line thickness of 0.44mm but infill is quiet poor, unusable.
Also printing speed of the first layer doesn't seem to be affected by first layer speed reduction...
When printing with Makerbot Desktop or slicer, line thickness & infill are good.
Would appreciate any hints how to fix this, added my settings below.
Regards
Alex
Nozzle: 0.4
Regards
Alex
; G-Code generated by Simplify3D(R) Version 3.1.0
; Jun 29, 2016 at 7:47:12
; Settings Summary
; processName,Process1
; applyToModels,Bauteil1
; profileName,CTC Bizer Dual
; profileVersion,2016-06-08 08:00:00
; baseProfile,
; printMaterial,PETG
; printQuality,Medium
; printExtruders,Right Extruder Only
; extruderName,Right Extruder,Left Extruder
; extruderToolheadNumber,0,1
; extruderDiameter,0.4,0.4
; extruderAutoWidth,0,0
; extruderWidth,0.4,0.4
; extrusionMultiplier,0.5,1
; extruderUseRetract,1,1
; extruderRetractionDistance,0.5,0.5
; extruderExtraRestartDistance,0,0
; extruderRetractionZLift,0,0
; extruderRetractionSpeed,1200,1200
; extruderUseCoasting,0,0
; extruderCoastingDistance,0.2,0.2
; extruderUseWipe,0,0
; extruderWipeDistance,5,5
; primaryExtruder,0
; layerHeight,0.15
; topSolidLayers,3
; bottomSolidLayers,3
; perimeterOutlines,2
; printPerimetersInsideOut,1
; startPointOption,2
; startPointOriginX,0
; startPointOriginY,0
; startPointOriginZ,300
; sequentialIslands,0
; spiralVaseMode,0
; firstLayerHeightPercentage,100
; firstLayerWidthPercentage,100
; firstLayerUnderspeed,0.25
; useRaft,0
; raftExtruder,0
; raftLayers,3
; raftOffset,3
; raftSeparationDistance,0.14
; raftInfill,85
; disableRaftBaseLayers,0
; useSkirt,1
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,3
; skirtOffset,4
; usePrimePillar,0
; primePillarExtruder,999
; primePillarWidth,12
; primePillarLocation,7
; primePillarSpeedMultiplier,1
; useOozeShield,0
; oozeShieldExtruder,999
; oozeShieldOffset,2
; oozeShieldOutlines,1
; oozeShieldSidewallShape,1
; oozeShieldSidewallAngle,30
; oozeShieldSpeedMultiplier,1
; infillExtruder,0
; internalInfillPattern,Rectilinear
; externalInfillPattern,Rectilinear
; infillPercentage,100
; outlineOverlapPercentage,25
; infillExtrusionWidthPercentage,150
; minInfillLength,0.5
; infillLayerInterval,1
; infillAngles,45,-45
; overlapInfillAngles,0
; generateSupport,0
; supportExtruder,0
; supportInfillPercentage,30
; supportExtraInflation,0
; denseSupportLayers,0
; denseSupportInfillPercentage,70
; supportLayerInterval,1
; supportHorizontalPartOffset,0.3
; supportUpperSeparationLayers,1
; supportLowerSeparationLayers,1
; supportType,0
; supportGridSpacing,4
; maxOverhangAngle,45
; supportAngles,0
; temperatureName,Right Extruder,Left Extruder,Heated Build Platform
; temperatureNumber,0,1,0
; temperatureSetpointCount,1,1,2
; temperatureSetpointLayers,1,1,1,2
; temperatureSetpointTemperatures,220,0,95,75
; temperatureStabilizeAtStartup,0,0,0
; temperatureHeatedBed,0,0,1
; temperatureRelayBetweenLayers,0,0,0
; temperatureRelayBetweenLoops,0,0,0
; fanLayers,1
; fanSpeeds,0
; blipFanToFullPower,0
; adjustSpeedForCooling,1
; minSpeedLayerTime,18
; minCoolingSpeedSlowdown,20
; increaseFanForCooling,0
; minFanLayerTime,45
; maxCoolingFanSpeed,100
; increaseFanForBridging,1
; bridgingFanSpeed,100
; use5D,1
; relativeEdistances,1
; allowEaxisZeroing,0
; independentExtruderAxes,1
; includeM10123,0
; stickySupport,1
; applyToolheadOffsets,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; overrideMachineDefinition,1
; machineTypeOverride,0
; strokeXoverride,220
; strokeYoverride,130
; strokeZoverride,120
; originOffsetXoverride,110
; originOffsetYoverride,65
; originOffsetZoverride,0
; homeXdirOverride,1
; homeYdirOverride,1
; homeZdirOverride,-1
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; toolheadOffsets,0,0|34,0|0,0|0,0|0,0|0,0
; overrideFirmwareConfiguration,1
; firmwareTypeOverride,MakerBot/Sailfish Firmware
; GPXconfigOverride,r1d
; baudRateOverride,115200
; overridePrinterModels,1
; printerModelsOverride,MakerBot_Replicator1.stl
; startingGcode,; **** Replicator 1 dual start.gcode ****,M73 P0 ; Enable build progress,G162 X Y F3000 ; Home XY maximum,G161 Z F1200 ; Home Z minimum,G92 Z-5 ; Set Z to -5,G1 Z0 ; Move Z to 0,G161 Z F100 ; Home Z slowly,M132 X Y Z A B ; Recall home offsets,M135 T0 ; Load right extruder offsets,G1 X-110 Y-60 Z30 F9000 ; Move to wait position off table,G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating,M126 S[fan_speed_pwm] ; Set fan speed,M140 S[bed0_temperature] T0 ; Heat buildplate ,M134 T0 ; Stabilize bed temperature,M104 S[extruder0_temperature] T0 ; Heat right extruder,M133 T0 ; Stabilize right extruder temperature,G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs,G92 A0 B0 ; Zero extruders,G1 X100 Y-60 F9000 ; Move to front right corner of bed,G1 Z0.3 F6000 ; Move down to purge,G1 X-80 Y-60 E24 F2000 ; Extrude a line of filament across the front edge of the bed,G1 X-90 Y-60 F180 ; Wait for ooze,G1 X-100 Y-60 F5000 ; Fast wipe,G1 Z0.5 F100 ; Lift,M73 P1 ;@body (notify GPX body has started),; **** end of start.gcode ****
; layerChangeGcode,
; retractionGcode,
; toolChangeGcode,
; endingGcode,; **** Replicator 1 dual end.gcode ****,M73 P100 ; end build progress,G1 Z150 F1000 ; send Z axis to bottom of machine,M140 S0 T0 ; cool down HBP,M104 S0 T0 ; cool down right extruder,M104 S0 T1 ; cool down left extruder,M127 ; stop blower fan,G162 X Y F3000 ; home XY maximum,M18 ; disable stepper,M72 P1 ; play Ta-Da song,; **** end of end.gcode ****
; exportFileFormat,x3g
; celebration,0
; celebrationSong,Random Song
; postProcessing,
; defaultSpeed,2000
; outlineUnderspeed,0.5
; solidInfillUnderspeed,0.8
; supportUnderspeed,0.8
; rapidXYspeed,2500
; rapidZspeed,600
; minBridgingArea,50
; bridgingExtraInflation,0
; bridgingExtrusionMultiplier,1
; bridgingSpeedMultiplier,0.8
; filamentDiameter,1.75
; filamentPricePerKg,46
; filamentDensity,1.25
; useMinPrintHeight,0
; minPrintHeight,0
; useMaxPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; diaphragmLayerInterval,20
; robustSlicing,1
; mergeAllIntoSolid,0
; onlyRetractWhenCrossingOutline,1
; retractBetweenLayers,1
; useRetractionMinTravel,0
; retractionMinTravel,3
; retractWhileWiping,0
; onlyWipeOutlines,1
; avoidCrossingOutline,1
; maxMovementDetourFactor,3
; toolChangeRetractionDistance,12
; toolChangeExtraRestartDistance,-0.5
; toolChangeRetractionSpeed,600
; allowThinWallGapFill,1
; thinWallAllowedOverlapPercentage,10
; horizontalSizeCompensation,0
G90
M83
G1 Z0 ; Move Z to 0
M127 ; Set fan speed
M140 S95 T0 ; Heat buildplate
M104 S220 T0 ; Heat right extruder
G1 Z0.5 F100 ; Lift
G1 E-0.5000 F1200
G1 Z0.150 F600
; layer 1, Z = 0.15
M135 T0
; tool H0.150 W0.400
