Multiple Process: Infil Patterns
Posted: Tue Jul 26, 2016 7:26 am
by GeorgB
I have 2 models. One should have rectlinear and the other Honeycomb Infil Pattern.
I defined 2 processes A and B from 2 different Profiles PA and PB (because one profile can only handle one type of pattern).
Now I select the models.
Now I "Prepare for print" for both models with the process A for part A and process B for part B.
Finally always the pattern of the "prepare for print" is active.
(no difference "Continous printing" or "sequential printing". )
Where is my mistake?
Re: Multiple Process: Infil Patterns
Posted: Tue Jul 26, 2016 7:47 am
I've just tried the same, following what you did....and the two infills are different as expected.
Can you attach your factory file and I'll take a look at it.
Posted: Tue Jul 26, 2016 8:04 am
by GeorgB
@Doug thanks for mail - what do you mean with factory file? the *.gcode? *.stl?
Posted: Tue Jul 26, 2016 8:36 am
Load your models and profiles as if you're ready to slice, then on File menu====>Save factory file.
The file will have the suffix .factory. It contains everything needed to replicate exactly what you're trying to do.
Attach to the post using the "Upload attachment" at the bottom of the posting page.
Posted: Tue Jul 26, 2016 8:53 am
by GeorgB
Doug, sorry - I am quite new ... and was not aware of this feature !
Thare are just 2 parts ..
Thanks for your help!
Posted: Tue Jul 26, 2016 9:27 am
Saving the factory file is the standard way of saving how you set up and printed something. Once saved, you can load at any time and be able to do an identical print.
And I think I've spotted a few strange things in your file.
Firstly, I get an error when reading the profiles in. Once for each profile "Failed to parse XML file" This may point to the cause of your problems..but I'm not sure. Clicking OK on each error results in everything loading.
Checking out the two profiles, neither had a model selected. I set one model to each profile.
I then spotted both profiles had rectilinear infill set. I changed one to honeycomb.
On slicing, one had rectilinear infill, and the other had honeycomb infill as I would have expected.
Try loading the attached updated factory file and see if you get a difference. I'd also try loading the factory file you saved to see if you get the same two error messages. If you do, then your original settings may be corrupted.
Posted: Tue Jul 26, 2016 11:04 am
by GeorgB
I have also those 2 errors.
argh - I made an user error: I selected the models on the wrong place.
Sorry it was my mistake, everything is ok!
Thanks for your time..
Posted: Wed Jul 27, 2016 2:46 am
by GeorgB
PS: I found out the reason for the errors:
I had german letters in the comments of the script commands (äüö..)
thanks again..
