Hi team,
I am experiencing a big quality issue with dual extrusion setting for soluble supports.
In order to have a good quality for the outer perimeter, I print inside -> out with the same speed between perimeters and only retract when crossing open spaces. Which is the only way to have a good finish for me.
It works fine making retraction only when finishing the outer perimeter or crossing open spaces.
Printing dual, i have enabled ooze shield (and prime pillar). Since I have no retraction between ooze shield and part. This is not acceptable in terms of quality for the outer perimeter.
I have disabled the "only retract when crossing open perimeters", so there is a retraction between the ooze shield and the inner perimeter, fine.
BUT THERE IS ALSO A RETRACTION BETWEEN PERIMETERS CREATING A BLOB AT THE STARTING POINT OF THE OUTER PERIMETER.
As it is fine print, I cannot increase the coasting too much, otherwise I loose details. Negative extra restart distance doesn't help that much.
Currently I cannot sell the parts printed due to that bug ! I've paid a premium for that software and ROI is compromised.
Please provide a fix ASAP ! I'm running 3.1.1 version.
Best regards
David
