Akura2
Auxiliary PLA cooling fan control for Malyan M180
Sun Nov 27, 2016 7:58 pm
I have printed a PLA blower fan adaptor for my M180 and installed a fan in the right-side position for testing... I've plugged the fan into the auxiliary wire located in the right front of the printer housing and it's a 12v 40mm x 10mm 8+ CFM fan as recommended...
When I go to print, the fan does not spin (I've tried two different ones and neither spin when printing starts) Is there something I'm not doing in the software that's keeping the fan from spinning up?
The fan gets warm when you touch the center where the motor is, but it doesn't spin up and I can hear the main board cooling fan speed up and slow down when I plug and unplug the fan.
I saw in the Wiki a set of command lines, but it doesn't specify it this will work with S3D, and where in the command they are supposed to go
From the Wiki:
M106 T0 S100 ; set pwm to 100, max value 255
M107 T0 ; disable pwm
Help
Thanks
brian442
Re: Auxiliary PLA cooling fan control for Malyan M180
Mon Nov 28, 2016 5:43 am
Did you try putting one of those commands in your starting script?
Akura2
Mon Nov 28, 2016 3:33 pm
Yes... but I wasn't sure where in the script it should go... newbie here...
shocksofmighty
Mon Nov 28, 2016 9:24 pm
Try switching the polarity on the fan leads. The blower fans won't just spin in reverse if the leads are backwards. I found that one out the hard way.
Akura2
Mon Nov 28, 2016 9:37 pm
Never thought to switch the leads... the 'red' went to the 'red' and 'black' to 'black' and the plug 'fit' but something may be reversed... I'll try it and see
shocksofmighty
Mon Nov 28, 2016 9:45 pm
Akura2 wrote:Never thought to switch the leads... the 'red' went to the 'red' and 'black' to 'black' and the plug 'fit' but something may be reversed... I'll try it and see
I bought an aftermarket fan for my FFCP and found that despite the colors, the leads were reversed. It was as simple as just yanking the wires out of the connector on the fan and reversing them.
If that isn't it you can always use a voltmeter and test to see if you are getting 12V out from the bot when the fan should be active.
Akura2
Mon Nov 28, 2016 11:21 pm
That's what it was... a revered set of wires... fan works great now... I just need to see after this print if it was worth the mod
YAAAAAAAAY!
