totalitarian
20mm test cube - strange corners and unequal lengths
Thu Jan 19, 2017 2:09 pm
Printed on Flashforge creator pro 50mm/s pla @ 195 degrees. Glass bed @50degress
https://goo.gl/photos/t79TDevyhw9Euzc87
Also the the x dimension is 19.95 and the y dimension is 19.85
How do I combat x and y not measuring the same?
Also I notice the slicer finishes the outside shell in a different corner each layer. I presume the corners look like they do because of this? Would coasting help?
brian442
Re: 20mm test cube - strange corners and unequal lengths
Fri Jan 20, 2017 4:06 am
You can change the start point option to "choose start point closest to a specific location" if you want it to always start in the same corner
