Nyrk2k
Dremel 3D40 not working after firmware update
Mon Jan 23, 2017 1:51 pm
My Dremel3D40 has received a firmware update yesterday.
Afer that Update, Simplify 3D Profil doesn't work.
The Extruder doens't head up...all Code in Script doesn't work anymore.
Is there anybody with the same Problem?
Nyrk
P.S. Simplify with Dremel3d40 over USB has never worked
brian442
Re: Dremel 3D40 not working after firmware update
Tue Jan 24, 2017 5:45 am
Does it work from the SD card?
Nyrk2k
Tue Jan 24, 2017 3:19 pm
no, after the Firmware update...the Extruder dos not head up.
usb Connection has never worked
brian442
Tue Jan 24, 2017 7:13 pm
hmm.. well did you try asking the Dremel support people about it? Maybe they have release notes for the firmware or can tell you what changed.
Nyrk2k
Wed Jan 25, 2017 2:20 pm
I have been waiting for a callback from Dremel for two days. The nice gentlemen on the phone did not know anything.
smutlygimo
Mon Jan 30, 2017 3:30 pm
I too have this problem. ive been chatting back and forth with Dremel for 5 days now VIA emails. they are sending me a flash drive with the old firmware files that came with the printer. i will try and keep you up todate on this.
smutlygimo
Wed Feb 01, 2017 11:05 am
Hey guys i got the "older" files for my Dremel to work. you need to contact dremel and ask them to send you older files for the update.
brian442
Thu Feb 02, 2017 4:45 am
Can you post the old files here? That will make it much easier for anyone else in the future that has to do this
DarthRevan
Thu Feb 02, 2017 5:47 pm
All you need to do to get the files to work from the flash drive is wrap the heating commands in a pair of these fancy comments
Start of your files should end up looking very similar to the files produced by autodesk...
DREMEL HEADER
; Selected Profile: Dremel 3D40, Standard
; Selected Printer: Dremel 3D, Idea Builder 3D40
G90
M82
M107
M104 S220 T0
M6 T0
I've linked the profile I'm using for now. Hopefully it helps you guys out. :geek:
Dremel Idea Builder 3D40 (2017_02_02).fff
(10.3 KiB) Downloaded 570 times
jongallant
Wed Jul 05, 2017 3:11 pm
DarthRevan - I used the fff file and exported a g3drem file to a USB stick. When I hit USB on the Dremel console it freezes.
