terry1956
just not printing
Wed Apr 05, 2017 9:03 am
hi. for some reason my Da Vinci 1.0 will not print an item. I have printed lots of things using the same programs and method. but for some reason it will not print.
The item shows up in the edit and gets send to the printer by usb cable. the printer then goes into print mode and is busy following the g code. but at the end I don't have a print. if I load a second item it prints ok. so the fault is in the set up for the first part. can anyone help me out. the file I am trying to print is below. thanks. michael
must use this wheel for 4-8-0 3 rail loco.STL
(90.8 KiB) Downloaded 84 times
terry1956
just not printing
Wed Aug 01, 2018 9:26 am
ok, tried to print a part again today. the printer printed the oval thing ok, which lifted the nozzle z axis 2mm from the bed. but when it started to print the main body of the part the nozzle did not lower and remained at 2mm above the bed, so no print. what am I doing wrong ????
Reason: match title after merging posts
