just not printing
Posted: Wed Apr 05, 2017 9:03 am
hi. for some reason my Da Vinci 1.0 will not print an item. I have printed lots of things using the same programs and method. but for some reason it will not print.
The item shows up in the edit and gets send to the printer by usb cable. the printer then goes into print mode and is busy following the g code. but at the end I don't have a print. if I load a second item it prints ok. so the fault is in the set up for the first part. can anyone help me out. the file I am trying to print is below. thanks. michael
