glx51mm
Re: Wipe While Retracting...
Tue May 13, 2014 5:38 am
Can someone verify if this issue has been addressed in 2.1.0 ?
laird
Tue May 13, 2014 11:17 pm
+1. Nice find!
jwiede
Wed May 21, 2014 9:29 pm
+0.7
theray
Mon Jun 09, 2014 7:30 am
Got the same problem with a Rostock Max v2. I found the same workaround works but i can't change all the retractions by hand so i had to make a little gcode translator for modifing these lines... I would like to see a check box on the print settings that allow to choose the standard retraction system or the one explained here. Rectraction and next move merged in the same line.
stevedev
Mon Jun 09, 2014 3:20 pm
+1
neobobkrause
Mon Jun 09, 2014 7:24 pm
+1
prcdslnc13
Fri Jul 04, 2014 12:24 pm
Did this ever get fixed? Im still having similar issues in 2.1.1
HBWray
Mon Jul 07, 2014 2:55 am
+1
Please fix this I am having issues with this is 2.1.1 as well.
vOidward
Mon Jul 07, 2014 3:02 am
prcdslnc13 wrote:Did this ever get fixed? Im still having similar issues in 2.1.1
Nope, still pauses before a wipe in 2.1.1
thews
Mon Aug 11, 2014 5:04 pm
Can you post your script to modify the gcode?
theray wrote:Got the same problem with a Rostock Max v2. I found the same workaround works but i can't change all the retractions by hand so i had to make a little gcode translator for modifing these lines... I would like to see a check box on the print settings that allow to choose the standard retraction system or the one explained here. Rectraction and next move merged in the same line.
