JFettig
Re: Wipe While Retracting...
Fri Feb 13, 2015 9:13 am
TenKOhms wrote:
JFettig wrote:I'm surprised this thread is so old and they haven't done anything about it!
Any tips on how to run that ruby script? I've installed NP++ and Ruby, definitely not much of a programmer.
instructions are in the comments at the top of the script:
#filepath = "/home/user/whatever.gcode"
#chmod +x this file
# ./thisfile.rb "/file/path.here" > "/new/file.path"
might as well be greek :P
MaOb
Thu Feb 19, 2015 11:45 am
is it possible that this issue has been fixed in s3d 2.2.2?
BR, Martin
JFettig
Fri Feb 20, 2015 9:04 am
It still pauses, blobs, then wipes.
Fri Feb 20, 2015 10:59 am
Just to be clear, what is currently does is print, retract immediately after completing the loop, and then wipe. There is no pause. It is a retraction movement.
It seems like some people may have their retract speeds too low if this is actually a long pause. Retracts are typically very quick.
JFettig
Fri Feb 20, 2015 11:01 am
100mm/s too slow? There is a pause while it retracts, a long Bowden tube has a ton of compression on the filament, and it blobs. Direct drive and it wouldn't have an issue because retractions could be really short. I have to retract 6 mm or it strings.
Fri Feb 20, 2015 6:45 pm
Why don't you try some coasting to help relieve the built up pressure then? A 6mm retract at 100mm/s would only take 0.06 seconds.
JFettig
Sat Feb 21, 2015 10:08 am
I do coast, it makes a seam and is inconsistent if I turn it up. That retract definitely takes more than .06 seconds by the time motion stops, the filament accelerates and decelerates - it probably doesn't even make it to 100mm/s in that short distance.
bot
Sun Feb 22, 2015 4:00 pm
It takes longer because of acceleration settings. Often the extruder stepper axis has very conservative acceleration and jerk firmware settings. It likely never even makes it to 100mm/s if it's taking so long.
madeinoz
Sat Mar 14, 2015 11:05 am
+1
I've just come across this problem printing nylon on a bowden extruder and is can see a noticeable pause at the retractions which are causing blobs
illbeback2
Fri Mar 20, 2015 4:53 pm
+1
