Multiple print sequential ordering
Posted: Sat May 06, 2017 5:14 pm
Due to the off-centered positioning of the hot end on my print head, I would like to print from left to right on the bed. Due to a low gantry height (12 mm), I need to print the parts in two sections in the vertical direction. If I set both the parts and processes in the correct order, I can repeatably have the first 12 mm sections of the parts print in the correct order. However, probably for better mechanical properties at the section break, the last part continues on and prints FIRST of the top collection of part sections, instead of going back to the first part on the left, and printing left to right again. See image for reference:
Is there any way to force S3D to do this? If not, is there no-learning curve program to convert .gcode to a .x3g file, so that I could just copy and paste the .gcode around to the desired order and convert it to a .x3g? I am doing this on a Qidi Tech that unfortunately does not use convenient .gcode that I can open up in Notepad++.
