Sparse Top Fill
Posted: Fri Mar 14, 2014 5:54 pm
I recently purchased Simplify3D. So far I like it. But I'm having an issue with the top layer.
Is there a way to change the top infill settings? Anything that is solid just doesn't seem to be extruded as thick as it should be. I'm printing PLA and changed the filament multiplier to 1.0. The filament diameter is correct as well. I can't find any other settings to increase this other than just upping the filament multiplier even more. I actually went up to 1.15 for the multiplier and that was enough to cause the extruder to skip at times on the top fill...but there were still gap even in the areas it wasn't skipping For comparison here's a block that I printed with Simplify3D (left) and one i sliced with Slic3r (right). On the Simplify3D one you can easily see between the top layers where the Slic3r one is solid. Slic3r has the ability to slow down on the top infills (which I do) and Simplify3D doesn't seem to have this option so maybe that is something? The bottoms look pretty good, with no noticeable gaps..
I've been making adjustments to the Replicator 1 Dual profile in Simplify3D and printing from SD. Printing on a FlashForge Creator at 190C/60C at 4800mm/min
Thanks,
Jared
Thanks,
Jared
