hi all,
on repetier host the nozzle temperature reach's it' set temp, in simply 3d it always settles between 1 or 2 degree's short and never starts the print.
is there an adjustment for the temperature readings at all?
or how do i sort this out?
it's a Melzi 2 V3 tronxy board running repetier 9.1 (no options for uploading marlin untill i get a programmer and run the gauntlet with that BS.)
other issues are the board wont accept PID tune or read the eeprom setting comands. The axis moves and the extruder will exstrude, homing works too.
