[SOLVED] Coasting Distance: Has no effect?
Posted: Sat Aug 12, 2017 4:24 pm
by AK_Eric
I've been using S3D for a number of years now, pretty familiar with it, but I'd never used the 'Coasting Distance' option : Have a bigger nozzle, getting some blobbing a the end of the extrusion that wipe isn't addressing, so I figured I'd try this.
And try I have: Probably 5 different test-cylinders broken into 5 processes each with difference coast settings. And none of them look any different. Tested this in both S3D 3.0 & 4.0. Save factory file, closed/reopend the software, turned the checkbox on\off \ resave etc. It just does, nothing.
Here's a pic of my end results. The nozzle is traveling screen left -> right, so the left side of the zipper coasting should address. I also turn off my fan briefly between sections so they're easier to tell apart. In this case, all the same:
Here's a pic of the gcode: Clearly there should be some gaps forming, since I put some really big values in there (2mm for example):
I did another test with even *bigger* values, still no effect.
Here's my factory file for inspection:
no_coast.factory
(16.59 KiB) Downloaded 343 times
I'm using a custom build core-xy printer with RepRap Firmware runnnig on RADDS, .6mm volcano nozzle & bondtechBMG extruder.
Any thoughts as to why this would be happening? I'll attach my gcode in the next post.
Re: Coasting Distance: Has no effect?
Posted: Sat Aug 12, 2017 4:25 pm
by AK_Eric
And here's the gcode:
no_coast.gcode
(136.22 KiB) Downloaded 503 times
Posted: Tue Aug 15, 2017 12:01 am
by AK_Eric
Contacted S3D Support: With really big vals, like 5mm and greater, I'm starting to see some effect. Guess I didn't aim big enough to start.
Re: [SOLVED] Coasting Distance: Has no effect?
Posted: Fri Jul 10, 2020 12:55 pm
by nkuck
Have you been successful in really getting this resolved? I’m up to a coasting value of 16, still with no effects. :x
Posted: Fri Jul 10, 2020 3:29 pm
by airscapes
Just curious what artifact coasting is supposed to fix, never used it.. Oh NM layer change..
Posted: Fri Jul 10, 2020 8:11 pm
Too late at night for me to be bothered repeating what can be found elsewhere!
Read these:
viewtopic.php?f=8&t=1980
https://www.simplify3d.com/support/prin ... -and-zits/
And btw.......coasting DOES work. You just need to know what it does first to be able to recognise what it's effect is!
