Hello, i recently updated my Wanhao Duplicator 4s with the latest salefish firmware, and after that it has not been itself.
I can heat the bed temp on the printer itself, but when i use the S3D software it will not heat, sd-card and usb cable alike. When i used the software earlier it works perfectly, now its off for some reason. Any good ideas what im doing wrong ?
; **** Duplicator 4 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-120 Y-70 Z30 F9000 ; move to wait position off table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T0 ; stabilize extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-115 Y-65 Z0.15 F1200 ; slow wipe
G1 X-110 Y-60 Z0.5 F1200 ; lift
