Lonestar9192
Re: Major bug, x-axis leaning to the right (positive)
Thu Apr 10, 2014 9:35 am
Yes I rotated the object and even changed the features a bit and redid the stl. Still leans. It has to be how s3d is communicating with the printer. Repetier never had an issue like this
dmulheimer
Thu Apr 10, 2014 10:54 am
12
Lonestar9192
Thu Apr 10, 2014 12:05 pm
Same directions. It's both x and y in the same direction. I slowed the printer down to 80% and still did it
Binni1969
Mon Apr 14, 2014 7:14 am
Problem still exists in 2.1.0...
Festus440
Mon Apr 14, 2014 7:47 am
Binni1969,
Not sure if this is a factor. I did a preview of your body_frame model in S3D and there are visible gaps which would indicate errors in the STL file:
Did you check it using the "Repair" option in S3D?
Could you upload the STL file?
dmulheimer
Mon Apr 14, 2014 4:29 pm
12
Festus440
Mon Apr 14, 2014 5:36 pm
dmulheimer wrote:Festus440, what you are observing is a knowed problem with Simplify3D gcode preview and not a problem with the STL.
Okay.......
So then does Repetier Host have the same problem????
Mon Apr 14, 2014 8:03 pm
Yes i agree, i have slice tons of models over the past 9 mos and if you see that then there is a problem with the model. I have never seen an issue with the s3d preview.
dmulheimer
Mon Apr 14, 2014 8:31 pm
12
Lonestar9192
Mon Apr 14, 2014 8:59 pm
So how is any of it fixed?
