I have an odd situation where support is not generated for an object that has been rotated. I probably don't understand how to do supports properly, but in any case, here's the issue... I'm printing the INMOOV part "coverfinger1". I've rotated it so that it's orientated 90 degrees, giving it a vertical aspect.
I then try generating supports. I see the following in preview...
I really doubt those unsupported overhanging parts are going to print. Here is the settings page for the profile.
Note the 45 degree setting for supports, though I'm confused about that note "only used if manual support is not defined" - no idea about that. I have to jack the "maximum overhang angle" down to 1 or 2 before I see what I consider to be genuine supports for this object. I really suspect I'm just not understanding how to define supports properly. Is this a bug, or a user error?
Is this a bug maximum overhang angle being incorrectly calculated for rotated objects, perhaps?
