Respect endstops in RepRepFirmware when jogging?
Posted: Wed Sep 13, 2017 4:07 pm
I'd posted this question over on the Duet3d forums (home of RepRap Firmware), currently not coming up with much, thought I'd check here too.
https://www.duet3d.com/forum/thread.php?id=2617
Anyone who uses RepRapFirmware know how to configure S3D so that its jog controls (via the Machine Control Panel) will respect the endstops? My machine homes just fine when pressing the home buttons.
But say, if it's 10mm away from the X endstop, and I accidentally hit the "Jog -100 on X" button, it'll crash right into it making horrible sounds.
Presumably this is because S3D is sending a
not a
to the printer: RepRapFirmware suppoprts an additional 'S1' parameter that tells it to 'detect endstops' during G1 motions.
And S3D's 'Firmware Configuration' window has no special field for issuing G1 commands.
https://duet3d.com/wiki/G-code#G0_.26_G1:_Move
I've learned to be 'very careful' when using the jog controls, but it still happens to me from time to time: Anyone come up with a solution? Am I missing something basic here?
Thanks!
G1 X-100
G1 S1 X-100
Thanks!
