Bridging improvements in v4 are great but.....
Posted: Thu Sep 28, 2017 10:38 pm
by SteveIsHeer
I like the new settings for bridging as it gives way more control over that aspect of the print BUT..... why is it if I take a 20mm x 20mm x10mm high solid cube and tell S3D to print NO infill, 2 perimeters, 5 bottom and 5 top layers, it doesn't treat the first top layer it prints as a bridge? I have tried the bridging setting to use a bridge on anything over 5 square mm in size yet it does not use bridging settings. Yet, it will use bridge settings when covering the lettering on the bottom of the 3dbenchy model which is a way smaller area than the above mentioned cube.
Can anyone explain why it works like that?....
Re: Bridging improvements in v4 are great but.....
Posted: Sat Sep 30, 2017 12:25 am
by gearsawe
When you tell S3D to not infill it the block it still treats the area inside the perimeter as normal inside. You would have to build a cube which has been shelled out with some thickness like the left block below would bridge. This would be more of a request for a new feature. basically you wish the start of the first couple top layers to use bridging settings.
