I'm making a dual-extrusion print on my Flashforge Creator Pro, using the dual-extrusion wizard in Simplify3D.
I have the Left Extruder set to 200°C for layer 1.
I have the Right Extruder set to 200°C for layer 1, then 58°C after layer 20.
When the print gets to layer twenty it drops the temp the requested 58°C But i does so on the Left Extruder ( the wrong side) even though the setting is setup for the Right Extruder.
I have chedked all the setting, it prints the right color/features for the assigned extruder, for some reason the Code to change temp is being sent to the wrong extruder.
Any ideas of what is casing this mix up?
